- 15 Sep 2006
- Liverpool
How important do you think it is to have someone there to correct your form when first learning to squat/deadlift/bench press etc?
I've recently been hitting the gym in an effort to surprise my better half when she returns in September. I've been going for the past 17 days straight and I'm pretty pleased with myself for managing to do that, but my body is flagging a bit and I have a few questions I need to ask.
Other than that, I've made quite a lot of progress this year.
- In the first few days I started, I was able to do a fair bit on the chest press, pectorals and shoulder press. Gradually that's fallen and today I was unable to do even half what I had previously managed. Fortunately my protein arrived in the post today so that should help, but is this normal?
- Any issues with wearing ankle straps? I'm fairly heavy and they really do help in my half-hour of cardio.
- My left-side is a lot weaker than my right, I have dumbbells but I'm really not keen on using them as room in my accommodation is lacking.
July 2013 - 324.6lbs
December 2013 -292.8lbs
January 2014 - 281.6lbs
March 2014 - 273lbs
May 2014 - 271.4lbs
June 2014 - 250lbs
My target is 210-220lbs. I feel that I can get there and I'm pretty determined to do so.
How did the form look to you mrthingyx?
If you go for a sudden reduction in calories and push your body into an exercise routine, it won't be too happy!
Your body is telling you it is knackered and not repairing properly between exercise bouts. This calls for two things:
1) A balanced and appropriate diets;
2) A balanced, structured and progressive free weights regime.
Cardio is not required to lose weight, and if your ankles are hurting when doing it, the simple answer is to do something else (assuming you have a real need to do cardio in the first place) like swimming or cycling. I would always suggest hitting the weights first...
Finally, it is not uncommon for most people to have a dominant side, either through left/right handedness, or underlying biomechanical issues that have never been corrected but reinforced. This is why lifting weights is - again - better than cardio, because the iron doesn't lie and will highlight any imbalances in your body and motor activity.
So. Have a look in rhe OP of this thread as there are a lot of links to threads on diet and potential routines.
Good luck and keep going.![]()
Does it matter, and do you care?
Sure you lean back a fair amount and there's some elbow flare, but it's 110kg...![]()
Thanks for the reply, much appreciated.
Today was a mixture of good and bad for me at the gym. Did the most cardio I've ever done, 1km running at 10 km/h before doing 7.5km on the bike (at 25 effort) and then 30 minutes on the crosstrainer.
Then I hit the weights. Weak as a kitten doesn't do justice to how pathetic I feel right now. I'm so tired on my arms and back it's not even funny.
2 days off from weights, and 2 hours of cardio this weekend. Going to be fun...
not.
