I've spent the best part of a weekend trying to overclock my pentium K, best I could get was 4.4 @ 1.428v. Has anyone got batch # 341B993 and able to get a decent overclock ?
What cooler are you useing ?
My batch number is 3418C001 if its of any use.
I'm running it on a custom loop.
i think it works on z97 but only with xeons?What chipsets does ECC memory work on?
not bad
Can't get mine to OC
I have a GA-Z87M-D3H with latest F10 BIOS; If I change the multi, the BIOS shows what I have changed it to, but actual stays at 32.
With my 2500K in a GA Z77-D3H, do the same, change multi, here the actual is the same as changed to.
So why? Am I doing something wrong? Is the mobo or cpu at fault?
Any help welcome.
