Are Mercedes doing a Red Bull on Hamilton or what? Rosberg must have a guardian angel or something..
Magnussen & Hamilton to start from the pit lane...
Screwing up qualifying like he did at Silverstone is fair enough as that was totally his fault, but ending up way down the grid because his brakes fail or his car catches fire in qualifying isn't.
Well, that's F1. Unfortunately, these things happen. Titles aren't solely won on driver skill and never will be, luck plays a part in everything in life.
What's luck. Hammy decided to use brembo even though there had been several failings in pre season testing, as for the other brake failure, he was in traffic, had more rear brake bias. Etc. No such thing as luck.
Doesn't his team mate have the same car? So if Lewis is having brake problems and engine problems, etc etc and the other guy isn't doesn't that just mean that while Lewis is driving great he's simply wrecking the car in the process?
And "the car" plays a much bigger role than skill or luck (with the obvious exception of 1976 ofc).
Ah yes luck. That tangible thing. Oh wait luck does not exist.
Brembo have a higher failure rate. This isn't luck. It is what it is. Each team has their own brembo pads specifically designed and made, cars don't have same cooling etc.
That engine mine also been the same as last race, in which case it's been pushed far harder than any of rosbergs engines.
There simply isn't anything called luck. Things happen for one reason or another, be it a mistake, extra wear and tear or what ever.
It's not bad luck he got a defect spark plug bit, it's a defective manufactured part.
Complete drivel...
Goof debating skills. You saying luck exists? Care to prove it?
You saying running in the pack which LH has had to do far more than Romberg hasn't put extra stress on most components?
You saying brembos don't have a higher failure rate? Stats show otherwise.
Unbelievable!Well that's it then, Rosberg is the WDC. Nothing more to see here..
Hamilton again!!!! Oh dear god. Disaster on this track. This championship is seriously over.
