So now with a good few members of the forum actually having screens, can we have some actual users opinions/reviews of the whole G-Sync experience?
I'm using the ULMB mode over GYSYNC in BF. I find it provides a smoother, more sharper experience.
Ultra Low Motion Blur![]()
I think its the amplified backlight/birghtness that came with the 3Dvision2.0 spec, a while back someone found how to force this extra brightness in 2d mode to deliver a relatively motion-blur-free output, Nvidia have since added this as an option available via NVCP as previously it required some wizardry.
Essentially its a different thing to G-Sync and its original intention was to improve 3d gaming![]()
ULMB is enabled and disabled via the OSD, very quick to do if you are running 120Hz or lower and not using G-Sync.
It strobes the backlight and produces amazing results similar to the best CRT gaming experience.
It is pretty much a game changer now I have it working right (had issues with 2nd screen enabled) and is better than G-Sync if you can maintain good FPS.
If you are playing something with lower FPS then switch back to G-Sync and it really smooths out the experience but if the frames get too low then it will feel laggy again.
The only downsides are the TN panel is still behind IPS for colours (although the Swift is the best I have seen) and no support for AMD (I have 290X in my other PC).
All the hype was for G-Sync but it really should have been for ULMB also!
Edit:
Also with ULMB mode the monitor (Asus Swift) has a separate brightness and contrast profile so you can calibrate it on and off and still maintain 120 cd/m2 when using ULMB at 100 Strobe Rate.
So no issues with it looking too dark or anything.
G-Sync - Makes Lower FPS range Feel smooth and playable which helps older hardware last longer before upgrading.
ULMB - Takes advantage of Higher FPS range and gives the best possible performance a modern monitor can give to get the best out of new hardware or older games (on old hardware).
Fully agree. After allot of testing this weekend I won't be enabling gsync anytime soon. If you can maintain solid frames its not necessarily.
Decent information about ULMB can be found here: http://www.blurbusters.com/gsync/preview2/#ulmb
Apologies for detailing the thread.
The cat is now out of the bag by many sources, and several news releases, so Blur Busters comments on the LightBoost sequel that’s included in all G-SYNC monitors!
All G-SYNC monitors include a LightBoost sequel called ULMB, which stands for Ultra Low Motion Blur. This is activated by a button on the monitor, Hz/activatable during 85/100Hz/120Hz mode
ULMB doesn't get rid of tearing though like gsync does, and after a few months of having gsync on, its very hard to disable it even for ULMB lol.
Good link but...
So will the Acer 4K have it or not? Its a G-Sync monitor but it only operates up to 60hz.
