Build log or not, we still like to see pictures. Primo porn is always wanted.![]()
Primo porn?
thats my new favourite category
Have you tried installing the fans directly beneath the filter ?
This is where I have my fans installed, because I have my radiator hanging
directly below them.
Also, how do you know if you have Version 1 or 2 case, just curious
to what mine is,having just bought it recently.
Remove the bottom rear 140 and put it next to the other one at bottom,the cool air will help with video card cooling.
Was going to get the 750D but for air or water this case is way better.
Looks like a £40 case!...
but I seem to be having some problems with rattling - specifically of the upper case filter.
No rattling of the top panel here, but the plastic at the front does make a few noises just after i turn the system on. I used rubber bolts to mount the top fans as they allow the fans to slide along without marking the case.
For the v2 owners, have the clips that hold the panel at bottom front been improved? On the v1 model theyre quite hard to clip/unclip and can break easily.
That was something everyone thought would be fixed on the v2 mate. If my clips do break, im gonna do a mod with a few small magnets to hold it in place. Seen it on another forum so ill need to dig it out again.My front panel is hard to unclip.
