Simply wow, my dream car.
Was it pedalled properly or driven like miss daisy?
Going to remain a dream, £350k based on JZM pricing is the going rate. Theirs sold too!
The 911 did a great job, beating off cars such as F360, R35 GTR and RS5 with a clear victory:-
Best time during timing was 1:24.90 not bad as I was taking it easy (ceramics) and not revving much beyond 6500rpm, track conditions were exceptional. My previous best time when was on steel brakes so was pounding them was 1:23.60.
Later in the day when timing ceased a friend in an E46 M3 was lapping faster, but in fairness he was running full slicks which make quite a difference.
Having driven on all types of tyre now at Donnington you can expect:-
Decent Road tyre (Bridgestone, Michelin, Yokohama)
Semi Slick: 1-2s time reduction from road tyre
Full Slick: 2-4s time reduction from semi-slick
Full slicks transform grip levels, you would not believe it and its hard to make your brain compete that you really can turn in at such speed at get on full power so early and also brake so much later. Full slicks do however put a car under massive strain, so make sure the car is built to take it.
Going well now
Now, Oulton![]()
Looking into buying an 03/04/05 996.
Thinking the bog stock one - is this the Carrera?
What are they like for servicing costs? I saw every 2years/20000 miles which is fantastic! Not far off what my 1.4 focus does in mpg either - 35 extra urban v 40-45mpg in focus!!
Obviously tyres will be pricey but what about insurance and security etc because i don't have a garage - would be off road public parking.
Fixed cost servicing.
£265 minor
£395 major
£125 Check up
Every second year minor, every 4th year major, with an annual check up in between. I usually just get a minor service in between a) as I don't want 2 year old oil. b) get the use of a new Porsche of my choice for the day.
http://porscheownerservices.co.uk/servicing/?model=68
Insurance is pretty good, on road, good postcode £340 for me this year. 7year ncb, one accident 2 years ago.
Tyres aren't too bad, about 120 for a front 200 for a rear for PS2s.
Model Order is as follows:
Carrera (Cab/Coupe) or Targa
Carrera 4 (Cab/Coupe)
Carrera 4S (Cab/Coupe)
Turbo
By the sounds of it you're after a 3.6 Carrera which is 320bhp. Beware of the numerous engine issues, hartech or similar maintenance program is highly recommended, I would worry about an untouched engine at this age with the problems they have had.
This seems the best place to put this, where's the best online resource for Cayman buying and info etc?
Less than £500 f/c on Carrera so double my focus insurance but not completely insane.
A couple of good forums would be the place to start the ones I use are boxa.net and 911uk.com both of these have sub forums with buying guides and cayman sections.![]()
