X79 Overclocking Guide
He jsut mean manually set them teh same.
TREFI 7936 is best balance.
Otherwise thats pretty tight timing. Maybe 9-11-10? pr TWCL 5 or thirds 3,3,0,0,4 or 3,3,0,0,3.
Not much to improve on. Good tuning.
Ah it's cos one set goes lower on the voltage than the other if i do that by about 20v or more.
Cheers will try those timings tomorrow, i feel like there is room to go further. These sticks are great.
Seems odd doesn't it? (I'm really not an expert here)
I thought Quad channel RAM sets would be matched better and was the reason why you don't buy 2 Dual Channel kits for Quad channel setups?
Blimey 20v :p
Yeah it's weird. I will snap a screenshot later. I have a new 1300W SF PSU coming today so maybe that will help things. This 1000W still does the job, but now i don't have to hold back the gpu clocks. Watch out Frosty, I'm coming for you. ;)
What's your physics score Matt in firestrike???
Got mine up 500ish pts running ram at 2450 8-12-8-20 (these may do cas 7 at this speed but not sure how much I can push the volts, these settings are at 1.8v) but this is in dual channel, need to source 2 more sticks of these so I can run quad but finding some is going to be difficult :(
@8Pack, what are max volts for PSC with high perf fans for bench??
Also get code 01 on board when switching ram, think the boards warping as test bench is acrylic and that bows from the weight. What is 01 code for??
Wasteful, just wasteful :D:p:D
It's early days and im not done yet. Having now spent a lot of time on it though im dying to play some games. Got my 1300W psu in now and just reinstalled windows, so will play some games for a bit then get right back on it. :)
01 RAM cant reach frequency with those settings or IMC is struggling to be trained.
PSC 1.85
