It's early days and im not done yet. Having now spent a lot of time on it though im dying to play some games. Got my 1300W psu in now and just reinstalled windows, so will play some games for a bit then get right back on it.![]()
Games are for kids!!!
01 RAM cant reach frequency with those settings or IMC is struggling to be trained.
PSC 1.85
On sandy e I found 125strap enabled me too push higher clocks at a lower voltage usually around the 128.5-130 Bclk range any higher and it started to effect max gpu core speed, you should be able to gain another 50-100hz on your comfortable max voltage. With ivy-e I'm finding not much difference between the 2 straps.
For gaming I just leave it at a flat 100.
.Nice timings mattis that at 2133??? Have you tried cas8??
Ram is at 2400Mhz.Thanks Nick. That's interesting so 125 strap could = lower core voltage on my cpu? That would be nice as my chip has a high VID.
only thing is strap clocking alter ram speeds my 2400mhz actually run at 2407mhz
Testing out a 4.8ghz overclock with the memory timings and speed used for my 4.5ghz overclock. Yikes i need 1.456v.
Wil do Nick if i can get it stable enough. These are just benchmark runs so im not going for complete stability but im not even close yet. Now experimenting with the strap.
