Manually set them to what you want
He jsut mean manually set them teh same.
TREFI 7936 is best balance.
Otherwise thats pretty tight timing. Maybe 9-11-10? pr TWCL 5 or thirds 3,3,0,0,4 or 3,3,0,0,3.
Not much to improve on. Good tuning.
Ah it's cos one set goes lower on the voltage than the other if i do that by about 20v or more.
Cheers will try those timings tomorrow, i feel like there is room to go further. These sticks are great.
Seems odd doesn't it? (I'm really not an expert here)
I thought Quad channel RAM sets would be matched better and was the reason why you don't buy 2 Dual Channel kits for Quad channel setups?
Blimey 20v![]()
I have a new 1300W SF PSU coming today so maybe that will help things. This 1000W still does the job, but now i don't have to hold back the gpu clocks. Watch out Frosty, I'm coming for you.![]()
is that at 2133??? Have you tried cas8??
Yeah it's weird. I will snap a screenshot later. I have a new 1300W SF PSU coming today so maybe that will help things. This 1000W still does the job, but now i don't have to hold back the gpu clocks. Watch out Frosty, I'm coming for you.![]()
At stock Nick it's around 14,500. 4Ghz cpu, 2400Mhz mems with timings above.
who runs stock????![]()
That's as far as ive gone so far.At stock Nick it's around 14,500. 4Ghz cpu, 2400Mhz mems with timings above.
Wasteful, just wasteful![]()
What's your physics score Matt in firestrike???
Got mine up 500ish pts running ram at 2450 8-12-8-20 (these may do cas 7 at this speed but not sure how much I can push the volts, these settings are at 1.8v) but this is in dual channel, need to source 2 more sticks of these so I can run quad but finding some is going to be difficult
@8Pack, what are max volts for PSC with high perf fans for bench??
Also get code 01 on board when switching ram, think the boards warping as test bench is acrylic and that bows from the weight. What is 01 code for??
