Man of Honour
- 29 Mar 2003
- Blurton
Don't put anything in the login/password section (untick "server requires login"). VM's servers are outsourced to Highwinds and will allow access via your VM IP address. If you still can't get on, check your logs and see what the error is (and post it here if it isn't obvious what the problem is).
You may then need to check that you have a reverse-DNS that resolves to a VM block. At that point you contact VM on their support forum and ask them to either fix your RDNS or have your IP added to the blocks recognised by the servers.
Thanks
SH2 is a bit hit and miss.
