Can anyone say for sure what is the max safe temp for the 4790k
sorry for the shout, but could not find an answer anywhere.
Nothing much to show, just more Vcore and more V going into the RAM at a value I dont think you got the stomach for![]()
Just noticed a strange thing on my chip this evening. Default voltage on this chip is 1.200, but when i checked this evening it was at 1.2800, (stock system). Only change i made recently in bios was to set XMP for my ram speed, timings and voltage. Seems this must override vcore too. Disabling fully manual mode on the voltage settings reset voltage to 1.200.
Btw Virus, that GTL 2.0 is pretty handy looking, much beter display of voltages than asus ai suite.
Adaptive voltage on vcore
48/48
2400 Memory
auto on vring no voltage needed.
just use the settings in my GTL 2.0 image you might need slightly higher vcore try 1.340v in your bios.
I got my 4770 up to 4.7 just now, but i'm not bothering with Prime
v core = 1.2929
vccin = 1.8
vring =1.1142 ( up by .010)
i've not touched anything else...all on auto...ram as well
let me know if this needs adjusting......thanks
IBT and Prime95 don't mean ****.
They have there purposes, so don't go saying they don't mean **** there useful.
Yes safe and Prime who cares. Test when gaming or using your rig.
Why does it need to run prime?? You play prime?? Just use normal applications to test prime is certainly causing temps and stress your system when used normally will never see.
I suspect it cant do 4.5+ with mem at 1600+ and the dropping of the ram to 1333 which is below IMC spec is helping a lot.
There is no way to Lock PCI X frequency with these CPU so thats not an option. If your CPU likes BLK though you can clock on the 1.25 strap with 36 x 125 giving you 4.5 run.
Have you also tried tweaking Cache volts (Ring Volts) SA, IOD and IOA. These can help in the case of IMC instability. Run the RAM at 1.65v it makes no difference and ensures stability.
Lol PCZ sadly you is wrong!!
IBT and Prime show only the ability to run Prime and IBT!! That is not stable. Who uses these progs daily?? The standard set by who.
I have seen several machines able to run this silicon torture for hours that cant drive 4 GPU.
In the case of Ivy E which you don't own. I know for a fact gaming and GPU stuff is tougher on em than 2D. XTU is a bench on HWbot based on Prime. WR for this chip is at 6340mhz, No ones Ivy E can run 3D at that frequency.
To test your pc use it for what you need it to do.
I have 5ghz Ivy E, SB-E, Haswell and Ivy's several of em and have tested literally hundreds of chips. Experience tells me how to test these systems not being dictated to by a standard that does not exist!!!
v core = 1.2929
vccin = 1.8
