- 7 Jan 2013
With 1 Piranha @ 80%, 32 and 30 respectively.
32 and 30 degrees at 80% load? How good is that bloody Piranha fan!
No. That one is throttled based on the temp of the coolant it seems.
Only if you plug it directly on power you will force it to run at 100%.
The question was Idle temps. So my idle tems are 32 & 32 @ 80% fan speed.
Full load is 72C & 67C while running Valley atm. (80% fan speed the Piranha still)
You have ulps enabled, which is why your second core shows as zero @idle.
Oh yeah I know that, I did some checking into that yesterday. But i've got it on atm for power saving currently.
Was more wondering where the hell in this version of AB my fan control had disappeared too, might have to revert.
We cannot manually control the fan on the 295X2.
The fan control is throttling based on the temperature of the coolant it seems, according to various sites they did a review on the card.
hi all well i got my r9 295 today with the asus pb278q monitor. All installed easily enough and the gpu temps are fine and dandy. The problem is for sum reason in bf4 and wow I can click on anything with my mouse. The cursor moves but nothing happens. Also there is a hell of a lot of screen ripping in BF4.
Any ideas whats going on? I have it connected with the the mini port display. When i used the dvi it would only goto 1080p?
Any ideas would be greatly appreciated![]()
So yes it turns out we can basically take 75mv off the core on these cards lol for super cool temps and still run them close to 1100mhz.....................the ram on them basically overclocks to the limit. I've tested it on mine too this batch of 100 cards must be like a golden batch. These have for sure been binned from the finest 290X chips.
Hahah
Soon will run this dual GPU beast with almost no power![]()
What are your settings at the moment?
I've been to -100mv and 1100mhz core 1650mhz mem.............seems to still work lol
People with idle temps of around 30c do you have push/pull on the rad or just push?
How much % power limit? my VRAM can only go to 1625 apparently according to MSI AB
Pushing cold air towards it.
You're right I'm running 1625 ram actuallyPowerlimit +50% of course it allows more power to the chips. Kinda limited to under 1100mhz by this limit else we'd be going crazy.
