Anyone going to be on this evening?
40/10 Fibre with Sky although I'm using Wireless 5Ghz bridges between my PC and the Sky Hub. I'm part of the testing team so can't change my Hub to anything else and don't want to run a cable. Ping times are usually mid-low 30's and I can pull 4.4MB/s through it.
Ah, so it probably is just an age thing then![]()
Doubtful, back is wrecked from deadlifting this morning.
You may need to check your form, if it's hurting badly it's probably not just DOMS.
Anyone recommend a reliable place to get BF4 Premium cd key at a good price?
Mexico. I hear it's fabulous this time of year. Use chrome and Hola.
Just to confirm you will NOT get banned for doing this, however EA will likely ban you from making future purchases from the origin store, you can still activate keys etc but if you ever intend to buy from Origin UK again, best not to do this...
Of course you can always create a new account if that happens
* and then don't play the game until 23rd / 30th as atm it is really bad but the new patch will make to 100x better
h80 ftw!!!*wishes for case space for a H100i though* (or H110i.... what ever is the biggest they have now)
