- 2 Jan 2012
- UK.
5930K 3.8 @ 1.14V.![]()
You're running at stock?
Yeah same with 5820K, max for single and two cores is 3.6Ghz but CPUZ shows 3.4Ghz, which is what all other cores run at.
Show me yours, stock etc and a few loops into super Pi.
3.8 now.![]()
Ah ok, I thought that was stock for 5930k.
You don't fancy pushing it further?
Stock is 3.5![]()
I'm a little worried about overclocking it more, i currently have 3 290's, board,cpu, 3 SSD's, 12 fans, 1 drive from a 1000W PSU, think i'm pushing my luck tbh!![]()
Yeah I def agree with that beast setup, leave CPU at stock.. Maybe switch over to 3 x GTX 980's? That could bring down the power usage massively, then you could clock the nuts of your CPU![]()
Is there someone here (Maybe Kaap?) that can compare Sandybridge-E to Haswell-E, both 6-core at 4.6GHz?
Or point me to where some comparisons have already been done.
Just wish either Intel would make a cheaper 4 core cpu for the X99 platform or ram prices go down
Running 4.5 here with my 5930k but using 1.348v, care to share your settings?
