- 10 Nov 2006
- Lincolnshire
Quick question will this card be better for 4K than 2X 290X's due to the memory?
No, 295X2 is 2x4GB just like having two 290Xs
Same thing with my 290's and my 750d, have to take the front panel off to stop them throttling.
All HDD bays are gone except 1. I did manage to add a third 140mm by sort of cable tying it into position. It's not too bad.
The top is taken up by my H100i, techically it only uses 2 slots, but there's not enough room up there for a third with it installed.
I think modding the front panel might be my only option at this point. Taking it off seems to make ALL the difference.
Did you guys manage to sort this problem out, I have a H440 and thinking of changing my CF290X's to a 295X due to throttling issues, I dont mind gaming with the front panel off as I do now but I still throttle at times, I dont want this with the 295X.
What is the consensus on Push Pull?
i found it strange that the setup of the radiator was expel the hot air although the air in your case might be hot..
think an un-optimized indie steam game has got me paranoid due to the card throttling during the game
thoughts?
Guys, if your card is throttling its most likely down to inadequate cooling! I don't think push+pull will make much difference, yes maybe 1 or 2c but is it worth with more fans=noise? I dont think so imo. Watercooling is the way forward if you want the best out of these cards.
I mounted my rad in the front now, same as TTL when he had the 295x2 in his test setup. not much change in temps but the tubes going off to the right just looks better to me.
For those with a H440, if you have a thick rad mounted in the roof and plan to mount the 295x2 rad in the rear, you might have some difficulty fitting in there. Other option for you is to mount it on the front I guess.
installed mine this morning 140mm incoming air and using the stock fan to pull
http://i1172.photobucket.com/albums/r580/Taintedgeek/Computer%20Stuff/IMG_0182_zps4e64b0be.jpg[/IG][/URL]
Ran a benchmark and no throttling so far .. temps seemed good, will have a play tonight
PS sorry for poor quality pic .. camera on iPhone 4s sucks[/QUOTE]
Exactly the way in planning on installing mine :)
why dont you buy an In Win D frame then you'll have no problems with cooling at all... but you'd better save loads of dosh, i think they look awesome
http://www.overclockers.co.uk/showproduct.php?prodid=CA-033-IW&groupid=2362&catid=2293
Well I've had notification from Overclockers that they have replaced mine, so they obviously replicated the issue.
Nice to know I wasn't being stupid.
