First of all, a big thanks to Karin at Silverstone and Rich at Overclockers for organising this!
I have some pictures for you!, although all I've had time to do as far is get the parts in the case (just!) and test them. Happy to report they are working a treat
First of all, some boxes:
They are all so small! The power supply box is stupendously small, when I first saw it I wondered how the hell they got a 600w PSU in there...
Anyway, at this point, I sort of forgot to do the "meet and greet" with the parts and had to put them together like an excited child.
After MUCH cramming, it all went in. Somehow.
Here's it opened up. I haven't spent any time organising it, this was just to check everything works.
It NEEDS a mention of hard it was to get that 770 in... had to be the first thing in, and had to go in on the other side IO end first, backplate facing the floor of the case. Then be twisted round above the motherboard, and finally coerced into place.
Lovely 600w PSU... IMO the star of the show here, solely for it being the absolute best SFX PSU about as far as I know
Semi-passive, gold rated, midget, modular... You get the idea
Here's a few pics showing the rest of the internals; the TD03, being such a thick rad, takes up SO much room!! I like it though, and it feels solid as anything.
The SSDs are ghetto mounted for now
Another top shot.
Showing the radiator from the inside; it really does dominate the case.
The other side; where I've shoved the currently unsleeved cables and SSDs.
My plans are obviously to sleeve the cables, with the colours I've put before. I'll have to think long and hard about management; James at Pexon can make them to custom length as he makes Silverstone cables from scratch, so that will help no end. The only real places I can see to practically route the cables are above the rad (for PCI-e) and below the rad (for... well, everything else
Also the window; not giving any details on this yet, but this will be the highlight I tell you now
Then there's the painting of the interior/rear, the repainting of pretty much everything
(the backplate is poorly finished and scratched, the IO shield is scratched, etc.), and the consideration of where I'll be putting this black/gold pattern.
Until next time.
