Just bought the original rumble roller, was going to buy one of the cheaper ones but realised I'd probably end up with a rumble eventually and it would have meant buying twice.
This sparks a question about your core and thoracic bracing...
I've found it a lot easier to brace with a narrower grip if that's what you're getting at?
Gotcha. I've not been feeling anything in my lower back to date so I think my bracing has been okay, I just feel a lot tighter in the narrower grip position, particularly at the bottom of the squat. I'll do a follow up form video at some point for you to take a look at.
I probably would still try to get out of the habit of supporting 180kg with your chest.
Shirted bencher drops bar on himself from half way up
Spotters always seem to miss these. You think there would be a better system in place for these heavy lifts given the dangers, like a mechanism of some sort that kicks in on the negative.
Even if if the spotter catches it they're probably going to put their back out in the process.
