why for nono and why for rolley eyes?
cheers guys...........had been using Valley tbh and when things were valley stable.....they were far from BF4 stable.
i notice your GPU temp = 81 degrees at 82% fan speed, this might be due to your core voltage being too high !!!! your GPU is under a lot of stress there, plus that software is more like Prime 95i would dump that software and run ``Heaven Benchmark`` instead, keep MSI though
redo your overclock from scratch and focus on reducing the core voltage, because your other settings are similar to mine
interesting !
Just tested my new pair of EVGA GeForce GTX 970 Superclocked ACX 2.0. Fans should not work at all until 60C is reach, shouldn't they? My ones work @31% even when gpu is @29C. I reinstalled drivers, no change. Am I doing something wrong?
Compared to my Msi 780 twin frozr Evga fans are much louder. Bought them quite cheap but I am not sure I will keep them.
Thank you. Found it but I will try it tomorrow because it so late.
Bit pointless, right, just wanted to check if new cards working allright![]()
You edited your post but I have a question about the first version. How come you can set fan speed to 0% when my minimum is 31%?. Drivers 344.48 btw.
why do people want to stress expensive graphics cards? is the extra few fps really worth ruining the life of it?
1: Because it's fun and virtually free extra performance - some people just like to squeeze as much value out of thier kit as possible.
2: They aren't that expensive.
3: You do know the name of the website you're on don't you?
4: With the limited voltage range available on the 970's, overclocking wont reduce thier lifespan. Voltage kills gpus/cpus, not clockspeed.
Asus Strix 970 GTX installed today. Utterly silent. Very fast. Good choice!
the 970 plays games at 1080p on my 46 inch tv perfectly, i have no desire to meddle with it or overclock it. why do people want to stress expensive graphics cards? is the extra few fps really worth ruining the life of it?
