- 28 Dec 2009
- Wales
Cheers mate, is it reasonably slim/low profile? Hard to tell from the pictures
Have to agree. If and when this issue is sorted out properly then I'll consider purchasing one but not until it is. Had I already purchased it, I'd be returning it for a refund in the interim.
I have nothing against Corsair (I have one of their cases and it's awesome) but high-end products like this shouldn't be launched when the manufacturers know full well that it doesn't do what it's claimed to.
Yes, another reason I got the K70 as I didn't want a wide keyb with macro keys. Remove the wrist rest and it's very compact, but it's looks better and the rest is actually quite decent.
Mine has the newer gaming logo, I know ppl have requested/wanted the original sails logo but I wasn't fussed.
Turn it off in CUE.
Open CUE, select the profile you use in the drop down menu then press the button with 3 lines on it to the side of the drop down menu, go down to where it says "type lighting" and uncheck "Enable" .
I am, of course, assuming this is the wave effect you mean, and not something else profile related.
Yeah, exactly my thoughts. I would have been happy enough with the K70 normal, but when this came along I thought why not...
Try it in a differant USB port. Are you using USB3 or USB2?Just got a CGK70 RGB and no matter what I try, I just cant get the CUE software to install. Every time I try I just get an unknown file association error, Open File Extension 77, does anyone know what im doing wrong?
