Dropped the temps with a side fan by 13C
This any good? ( Not for scoreboard ) Just went crossfire today
Kaap
I will take that no.1 spot please.
5960X @ 4.50GHz
2500MHz DDR4 C12-12-12-24-1T
Rampage V
Zotac 980 Extreme at 1565MHz Core and 8800MHz memory!
pushed +120MHz on core and +300 on mem with no extra voltage, when I OV it becomes unstable.. did you encounter any problem OVing?Hey Gibbo I have the same card what is your ASIC? Mine is a poor OCer I think and ASIC is 70.2%pushed +120MHz on core and +300 on mem with no extra voltage, when I OV it becomes unstable.. did you encounter any problem OVing?
Have you set the Power target to max?
110-130+ on the core for the Zotac is about right as its so quick out the box, they hit around 1550-1600 core speed when in 3D. It is the memory clocks which the Zotacs are best for, both mine do 8600-8800MHz memory clock, no other brand can achieve this apart from Asus Strix when hardware modified to take more memory voltage which voids warranty.
So what's he moaning about it being a poor overclocker for. Looks about right judging by your stats.
What does +300 on the memory equate to in MHz?
