With Fibre the estimates are mch tighter so you should really be getting those speeds. Are you sure the setup in the house is good? All sockets filters etc?
Thanks.
Will look into that.
I'm looking at this Asus RT-N53 for £30 - would that suffice and provide my wireless devices with my actual speed? (Distance dependant of course, but right ontop I'd want to see very close to wired).
Infact, is there anything cheaper that would suffice?![]()
Not really interested in much else router wise, except from getting the speed my wired gets (or as close to!).
Thanks all, hopefully you don't see it as too much of a derail as I'm sure it'll help others!
SR102 wifi sucks
After the wife complained the Sky wifi wasn't great I put it down to just being the stuff she was trying to access as it was OK for me, till this w/e. I went to play some stuff back on the PJ for the kids, it worked fine to begin with then suffered random drops/buffering less than 5m from the hub with a clear line of sight. I switched to a wired connection and it was fine again from the same source, back to wifi = buffering. I've had to resort to plugging in my (ancient) DDWRT based router in AP mode wich despite being 54g based has been rock solid ever since. I'll leave it till next weekend to confirm but I can see the SR102's days being numbered.
My question is am I better off firing up wireshark and grabbing the u/p and putting a custom firmware on the old Huawei modem and then going with a cable router (probably Asus with WRT etc.) or buying an all in one router/VDSL option? My gut reaction is the Huawei as if anything goes wrong it's easier/cheaper to replace.
Had the same issues here with the SR102. If I were to do it again (I went for an all in one VDSL modem/router, Billion 8800NL) I'd probably go modem (Openreach) and a top range router as you can restart the router and not drop sync as well as getting a better router.
That's about where i'd got to logically as it's a proven/stable modem and in the event of future upgrade its cheaper to change a non modem/cable router and the selection tends to be better along with firmware updates/hard reboots not loosing sync.So you have another socket somewhere else in the house? Is that socket being filtered correctly?
Do you have a filtered faceplate?
OK, the bottom section, what I would call the faceplate is what any other sockets in the house are normally wired to. This is so you can isolate them from the line by removing the faceplate. The now exposed 'test' socket becomes the only active socket in the property and is also the point at which responsibility for the line changes from Openreach/Sky to you. If there is wiring connected to the removable bottom section this normally indicates other sockets in the house.
Does your socket look like this?
If you mean they don't give dial tone with the faceplate off then that's normal as they're connected to the faceplate which has been disconnected. If you don't get a dial tone with the faceplate connected then I would suggest you have either faulty wiring in some way or a faulty telephone socket and this is reducing your speed.
