Big box for the memory!
Does it come with fans?
It sure does come with fans - but not able to use them as the watercooling tubes get in the way.
Also have this problems:-
Seems my no 1 bios is borked - updated to 802, and seemed to be ok, but as I was trying to set up the bios the machine would just shut down.
I have never seen this before. I checked/changed Psu/memtest runs on individual sticks then dual sticks etc, and could not identify the problem.
Bios 2 on 603 bios seems to work ok. Real hassle to swap the board out - as I would have to drain loop etc, etc.
Just built a 5960X system with Asus extreme v board. I then migrated my windows 8.1 Raid 1 to the new board using Macrium reflect
restore to different hardware - all fine except all my 5960X cores in dev manager have a yellow triangle mark - with the following message:-
A driver (service) for this device has been disabled. An alternative driver may be providing this functionality. (Code 32)
Have so far tried updating Intel chipset/ MEI drivers - but still the problem persists - any ideas how I can solve this driver problem?
Have looked in services msc for any Intel service not running - but can't see one - this is driving me nuts.
Anybody got any ideas on this problem?
Ps just found out that the cpu wont go past default 3.0Ghz even though I have set to 4.oGhz - seems the cpu is not fully recognised?????
Mark
