 - 8 Oct 2014
Still a little buggy in the GUI, but connection still holding steady I guess...
why not show your stats ? lol
	>wan vdsl2 show mgcnt;wan adsl perfdata
near-end path0 fec:     0(0)
near-end path0 crc:     24(193)
near-end fec sec:       0(0)
near-end err sec:       22(118)
near-end ses sec:       0(0)
near-end los sec:       0(0)
near-end ua  sec:       0(30)
far-end path0 fec:      63(17463)
far-end path0 crc:      9(1004)
far-end fec sec:        12(2148)
far-end err sec:        9(936)
far-end ses sec:        0(0)
far-end los sec:        0(129)
far-end ua  sec:        0(9314)
near-end FEC error fast: 0
near-end FEC error interleaved: 0
near-end CRC error fast: 24
near-end CRC error interleaved: 0
near-end HEC error fast: 0
near-end HEC error interleaved: 0
far-end FEC error fast: 63
far-end FEC error interleaved: 0
far-end CRC error fast: 9
far-end CRC error interleaved: 0
far-end HEC error fast: 0
far-end HEC error interleaved: 0
ADSL uptime : 1:09, 23 secs
	>tcapi show Info_Adsl
outDiscards=29
inDiscards=38
outBytes=513902708
inBytes=1472249995
outPkts=2267000
inPkts=2586042
fwVer= FwVer:5.5.1.125_B_A60901 HwVer:T14.F7_0.1
lineState=up
Opmode=ITU G.993.2(VDSL2)
SNRMarginDown=16.0 dB
AttenDown=10.3 dB
SNRMarginUp=9.7 dB
AttenUp=0.1 dB
DataRateDown=48999 kbps
DataRateUp=20000 kbps
WanListMode=1
FECDown=0
FECUp=69
CRCDown=28
CRCUp=10
HECDown=0
HECUp=0
ADSLUpTime= 1:20, 11 secs
ADSLActiveTime=0 min, 19 secs
PowerDown=11.9 dbm
PowerUp=4.1 dbm
AttainUp=27753
AttainDown=96012
ShowtimeStart=19
TotalStart=38
ATURANSIRev=0
ATUCANSIRev=0
ATURANSIStd=0
ATUCANSIStd=0
InterleaveDepth=1
AdslStandard=VDSL2
AdslType=ANNEX_B
mtenStandard=G.dmt.bisplus (Annex L)
	Early days but so far so good...
Usually I've knocked up hundreds of CRC errors by now.
I've now switched to the settings posted by simoncraddock - hopefully they will help. I'll keep an eye on the TC statistics.
EDIT 3:
It would seem the answer is yes. That being I can override the downstream DSLAM parameters (including max sync rate). My line is banded 49/20 yet I've now been able to get 80/20 by setting the max sync rate to 10000 (x8) = 80000Kbps.
This means the downstream DLM control can be overridden. Unfortunately this also may be susceptible to an abuser as this will most likely override even the 80 meg limit. However, I'm not interested in going beyond my package speed nor would I dare to try, but I do believe it would work (until you were caught perhaps by NOC, so I don't advise trying it).
EDIT 1:
Code:>wan vdsl2 show mgcnt;wan adsl perfdata near-end path0 fec: 0(0) near-end path0 crc: 24(193) near-end fec sec: 0(0) near-end err sec: 22(118) near-end ses sec: 0(0) near-end los sec: 0(0) near-end ua sec: 0(30) far-end path0 fec: 63(17463) far-end path0 crc: 9(1004) far-end fec sec: 12(2148) far-end err sec: 9(936) far-end ses sec: 0(0) far-end los sec: 0(129) far-end ua sec: 0(9314) near-end FEC error fast: 0 near-end FEC error interleaved: 0 near-end CRC error fast: 24 near-end CRC error interleaved: 0 near-end HEC error fast: 0 near-end HEC error interleaved: 0 far-end FEC error fast: 63 far-end FEC error interleaved: 0 far-end CRC error fast: 9 far-end CRC error interleaved: 0 far-end HEC error fast: 0 far-end HEC error interleaved: 0 ADSL uptime : 1:09, 23 secs
EDIT 2:
Code:>tcapi show Info_Adsl outDiscards=29 inDiscards=38 outBytes=513902708 inBytes=1472249995 outPkts=2267000 inPkts=2586042 fwVer= FwVer:5.5.1.125_B_A60901 HwVer:T14.F7_0.1 lineState=up Opmode=ITU G.993.2(VDSL2) SNRMarginDown=16.0 dB AttenDown=10.3 dB SNRMarginUp=9.7 dB AttenUp=0.1 dB DataRateDown=48999 kbps DataRateUp=20000 kbps WanListMode=1 FECDown=0 FECUp=69 CRCDown=28 CRCUp=10 HECDown=0 HECUp=0 ADSLUpTime= 1:20, 11 secs ADSLActiveTime=0 min, 19 secs PowerDown=11.9 dbm PowerUp=4.1 dbm AttainUp=27753 AttainDown=96012 ShowtimeStart=19 TotalStart=38 ATURANSIRev=0 ATUCANSIRev=0 ATURANSIStd=0 ATUCANSIStd=0 InterleaveDepth=1 AdslStandard=VDSL2 AdslType=ANNEX_B mtenStandard=G.dmt.bisplus (Annex L)
 just for ***** and giggles post the method and what tool required. also might help me get a even higher upload speed.I'd have thought that this would be expected since your connection is Interleaved rather than Fastpath - the whole point of interleaving is to add error correction after all.
I think you need to wait until your connection has recovered from DLM and is back on Fastpath before making any meaningful comparisons, assuming that you were not interleaved in the first place of course.
	Please Please Please tell me how to do that
my max sync rate is over 100megjust for ***** and giggles post the method and what tool required. also might help me get a even higher upload speed.
>tcapi get Info_Adsl lineState;tcapi show Info_Adsl
up
outDiscards=250
inDiscards=8767
outBytes=490636901
inBytes=1327493447
outPkts=1085576
inPkts=1379443
lineState=up
SNRMarginDown=12.1 dB
AttenDown=10.3 dB
SNRMarginUp=6.7 dB
AttenUp=0.1 dB
DataRateUp=19999 kbps
WanListMode=0
FECDown=2002704
FECUp=666
CRCDown=0
CRCUp=0
HECDown=0
HECUp=0
ADSLUpTime= 2:11, 11 secs
ADSLActiveTime=0 min, 18 secs
PowerDown=11.8 dbm
PowerUp=5.0 dbm
AttainUp=25394
AttainDown=110704
ShowtimeStart=18
TotalStart=154
ATURANSIRev=0
ATUCANSIRev=0
ATURANSIStd=0
ATUCANSIStd=0
InterleaveDepth=1517
AdslStandard=VDSL2
AdslType=ANNEX_B
 how the hell do you get out of bridge 4 mode lol after you change a setting....
as im connected at the new settings but no internet big yellow triange over my lan port
im guessing i have to get out of bridge mode 4 also can you email me the commands when you get a chance... for 80down 20up fast path and 90down 20up fastpath and 100down 25up fast path![]()
cheers.
Answered by email. I've yet to find a way to make multiple ports support bridgemode (not had the time to try) or to take a port out of bridgemode without a reboot. Changing the upstream speed isn't possible yet, unless there's a command somewhere that I've missed.
thanks for the new commands mate.
i will give those a try tommorow after work
though i know the 4th port cant be taken out of bridge mode like you said though if you find a way let me know.
now when applying the settings and pulling out the lanport and plugging it back into lan port 1 its showing a red x on my pc lan connection how do i get internet back after changing settings.....
the Asus was just chalking up way to many FEC errors behind the scenes
Interesting that you say that - just checked my stats via telnet and in one day, 17 hours or so my stats look like this:
FECDown=261849776
FECUp=738
CRCDown=3
CRCUp=89
HECDown=0
HECUp=0
I make that 261 million FEC - first time I have ever looked so nothing to compare against but it sounds awfully high.
>wan vdsl2 show mgcnt;tcapi get Info_Adsl lineState;tcapi show Info_Adsl
near-end path0 fec:      42614594(43207767)
near-end path0 crc:     553(397)
near-end fec sec:       22949(23517)
near-end err sec:       67(62)
near-end ses sec:       6(6)
near-end ua  sec:       0(31)
far-end path0 fec:      3128(28229)
far-end path0 crc:      0(1062)
far-end fec sec:        74(2446)
far-end err sec:        0(968)
far-end los sec:        0(160)
far-end ua  sec:        0(10332)
up
outDiscards=752
inDiscards=330
outBytes=409402589
inBytes=1929182410
outPkts=1238474
inPkts=1719640
lineState=up
SNRMarginDown=8.4 dB
AttenDown=10.4 dB
SNRMarginUp=6.5 dB
AttenUp=0.1 dB
DataRateDown=79991 kbps
WanListMode=0
FECDown=42614822
FECUp=3128
CRCDown=553
CRCUp=0
HECDown=0
HECUp=0
ADSLUpTime= 8:58, 30 secs
PowerDown=12.9 dbm
PowerUp=4.9 dbm
AttainUp=25327
AttainDown=106748
ShowtimeStart=19
TotalStart=1090
ATURANSIRev=0
ATUCANSIRev=0
ATURANSIStd=0
ATUCANSIStd=0
InterleaveDepth=424
AdslStandard=VDSL2
AdslType=ANNEX_B
tc>
Mine is doing the same while in interleaved. I can't make out if it's just the way it works, if it's reporting wrongly or if it's really errors being corrected. Personally I can't believe that many errors are happening. Surely there would be some noticeable throughput drop despite that many being corrected in such short time?
