Is it a reference card?
Edit ignore that, just seen it's not.
Have you tried changing your fan profile? This can help with temps.
Try 1150/1500 with more volts. Trixx can give you more voltage than MSI Afterburner can.
Find your max core clock, then max mem clock. You won't be able to get both running at max without instability, so find max and go back 10 on each. That's what I do, well, should do.
