- 30 Jun 2009
- Surrey, England
There's a "smoothness ironsight" setting in the config file, have you tried changing that from 1 to 0?
Yup tried turning it all off in the config.
Ah, maybe that's it. Does it go a long way it you don't fly too high? My first instinct with it is to get on top of a local hill.
Looks like you only get the Nvidia Godrays using an Nvidia card, funnily enough:
Shame
Ah right.
Enhanced didn't look that great in the screenshot comparison though?
It craps out if you fly too high. I wonder if there will be a perk that allows you to go higher?
Flew to about 6 radio towers last night unlocking the map. Fell off one and died and was sent back to before I even unlocked the first one. Does not auto save when you unlock a tower. Terrible.
its perfect playing without DXTory running and recording plus the upload that gives it that appearance humbug. Honstely dude completely flawless with no stutter at all.
+1
The save system is horrendous.
On mine if I esc I can manually save the game, or save and quit.
