Caporegime
- 18 Oct 2002
Come on children, play nice
No, I have an interest in Freesync and will enjoy having an input. You pulled up G-Sync and CS:GO, so don't have a dig at me when I say "turn off G-Sync" for that game and whilst we are here, what wi you be telling 4K freesync gamers to do when the frames are above 60? That is the refresh rate of that monitor.
60hz vs 144hz
That is a good question, if games give High input lag when maxing out Gsync 144hz - 144fps
Whats happens when you max out 60fps on 60hz... because that would then = 60hz Vsync = input lag without the frame stutter..
Limit fps to 60 turn off vsync get less tearing with next to no input lag (which I don't notice anyway)
If this was available on current monitors with a f/w update then amd would have a winner, The fact you have to buy a monitor for it to work puts me off unless there is a 4k 144hz monitor available for it.
What about the guys who sitting waiting for there next monitor upgrade? "Me"
4k 144hz now that's extreme future proofing..
Hey I am still on 60hz and happy so what do i know
I know if I had a 120/144 hz monitor I would be even less bothered unless like I said there was some super monitor at a reasonable price, like the rog swift features and res for 300 pounds.
Am in need to move away from 1080p... Badly
Here a question guys is the big difference between 1080p and 1440p like well worth upgrade?
I will never believe any BS hype about "higher quality TN" again after Rog Swift, I will try again once a Sharp VA type panel arrives like in the Eizo, in fact there is talk of one in the monitors section.
It helps if you make the right adjustments instead of just looking at it out of the box and sending it back
