Your 3rd board - yikes, that does not bode well. What has happened to quality control at Asus???????
Mark
Maybe i just got unlucky. I normally use Asus boards and don't have problems, but not had much luck so far with the Rog.
Mark
Perhaps they dont like AMD Matt??
Edit: just kidding fella!! Mines been sent off today so hopefully my problems will get resolved upon its return.
Good news as far as it goes - my replacement board has arrived. So all I have to do now is drain the loop and re build etc. I am hoping this will be the end of my woes, and I can get on to enjoying and playing etc.
Mark
Good news indeed. Hope this one is perfect!![]()
Many thanks - will report back, but initial setup looks promising.
Mark
All going well?
Fix the issue that the card installed on PCIE_X4_1 may be not detected if ASM106SE controller is disabled in BIOS.
A new Bios version 1001 has appeared on the ASUS site.
http://dlcdnet.asus.com/pub/ASUS/mb/LGA2011/Rampage_V_Extreme/RAMPAGE-V-EXTREME-ASUS-1001.zip
http://www.asus.com/us/Motherboards/RAMPAGE_V_EXTREME/HelpDesk_Download/
Not showing up on the Asus site - strange. Think I will hold off as no change details either.
Mark
Edit - not showing under downloads for win 8.1 64bit, but all others, go figure?
Anyone tried the new 1001 bios - any good, any problems? Wish they would be more specific about the issues fixed etc.
Mark
I have updated to the new 1001 bios and this bios seems to make the system more stable than the previous bios releases plus it seems to fix the annoying cold boot issues.
So far, there have been only positive comments from user using this bios.
https://rog.asus.com/forum/showthread.php?57077-BIOS-1001-released-1-28-2015
Hi Sylver,
Many thanks for the confirmation - will jot down my o clock settings and give this a go tomorrow. Seems on the whole very positive from the asus forums link.
Mark
