Just had a thought, it may be of help.
I hadn't touched skyrim for 6 months, and had an ENB working, I loaded it up and had the issue I described to you, so I decided I'll start from scratch and go down the MO route using the nexus guide and picking up mods as I came across them, like in your guide.
So this iteration is a build from a clean SKYRIM. Same problem.
Did you or are you using default profile in MO?
If so click on the next to gear icon and go to INI editor.copy paste you customised ini to it and save.this will create ini in you profile folder
Zia
Failed miserably at modding my skyrim.
Tried following and installing recommended mods on the realvision enb skyrim nexus page.
Went to run the game and its just closing to desktop every time...![]()
Yes, Default.
Yep clicked on the gear, gone to ini editor I have a skrim.ini and a skyrimprefs.ini - but paste them into what?
if you run skyrim with custmised ini tweaks.then you need copy the inis in My document\My game \skyrim ins to Mod organiser In Editor and paste them in the tabs i.e skyrimpref.ini and skyrim.ini
Therefore each new profile you create you can have different ini tweaks for different characters etc.
Zia
I haven't played for a couple of years, but yes, I can remember a Forge in Riverwood.Has the forge always been in Riverwood?
Lovely shots Devious, that with Serenity? Love the third from last, nice and colourful.
Please tell me that's been added in, otherwise I will have to hit myself in stupidity of not seeing it...
Yes serenity.
And sorry to say the forge has always been there![]()
You're kidding me, the amount of times I've fast traveled to Whiterun instead when I was crafting... I'm going to have to logon and check now...![]()
I was at work too! I've just gotten home![]()
Isn't one of the very first quests you can get when arriving in Riverwood a tutorial in blacksmithing using that very forge![]()
Thanks for the modlist Reaper. Installed most of your recommended graphical mods.
Do you know any good ones or .ini tweaks for more fps?
