- 28 May 2007
where are these dsr options i have 290x and cant see them in CCC
00
My digital flat panels and then enable virtual super resolution.
00
My digital flat panels>properties and tick the appropriate box. Select the resolution in game.
No you can't see the effect, you see whatever firefox/Chrome/IE deems appropriate for downsampling.
Wrong! I can see the effect very clear in my shots I have posted.
You don't get it.
Again.
No I do very clearly get it.
D.P's saying the image displayed in the tabbed window isn't the same as what your GPU displays, as the browser is doing the scaling/downsampling.
Sometimes I feel like I'm walking on egg shells around you. You just explode with rage.
To re-iterate you can't get what DSR is doing through the normal screenshot functions.
It starts by rendering the game at the specified DSR resolution in exactly the same way as it would for a monitor that was truly capable of the DSR resolution and when you screenshot this is what you get - the unaltered high resolution original with NO DSR processing - the drivers then intercept this before it goes to the monitor and use a filter to resample to native resolution.
So that's a no?
Oh well, I think the pics give a fairly good idea and they all show a clear difference for whatever it's worth.
And how do we determine what is lost?
So is there a clear way of providing fairly accurate pics?
Resizing via Paint/PS/Gimp is a no go or what? Do we have to then approximate with sharpening? If so, to what degree and how accurate is that in comparison?
Increase sharpening to your personal preference, just like DSR
Best is to use FRAPS or such like to take an actual in game screenshot when running DSR because that will include whatever post processing and sharpening DSR drivers are applying.
Open the csgo ones and flick between them, notice how much the aa level increase and how sharp the image becomes.
My personal preference shouldn't have any influence or bearing if we're talking about things being 'accurate'.
I use Afterburner to take screenies and these are all actual in game shots that reflect the level of DSR/VSR. I used MS paint to quickly resize it and saved it in the same format it arrived in.
What should I have done instead?
