Downloading both the 14.11.2 beta and Omega drivers. Are these meant to be used in conjunction with each other?
Interesting observation. May i suggest trying to uninstall the update i mentioned above then reinstalling the Omega drivers and see if the Mantle option comes back in Battlefield 4.
LoL ok false alarm.. i had BF4 set to 32 bit last night when i was trying to get Raptr to stream to Twitch tv and forgot to switch it back to 64 bit.
@Dave.. have a quick check of this just in case it switched to 32 bit on its own. I noticed a new plugin for battlelog, maybe that did it?
Im running 2560 x 1440 at 100hz on my 120hz monitorHi Dave,
Of course!
VSR is working as intended.
Here are the modes currently supported on the 1080p 120Hz display for a 290X.
3200 x 1800 1920 x 1080, 60 Hz
2560 x 1440 1920 x 1080, 60 Hz
2048 x 1536 1920 x 1080, 120 Hz
1920 x 1200 1920 x 1080, 120 Hz
For Battlefield 4 if you wish to downsample higher i would recommend using the ingame 'resolution scaling' option found in the video options.
Mantle is a 64 bit application only, so that makes sense.![]()
@AMDMatt will amd be adding VSR 4k res for the 290/x?
We intend to release a update to VSR in the near future that will improve on the number of cards supported (R7 260 or higher) as well as expand on the number of downsampling options.
Bleh always with the down sampling. Spare a thought for the few of us trying to use 'real' 4k on HDMI 2.0 TVs
Edit: NO. My sad face does not want to be wearing a christmas hat. Forum is ruining the effect.
I take it vsr doesn't work with eyefinty?
