- 5 Sep 2011
- Surrey
^ nice table, mines in blackshame the cpu cutout is not central on X99, wish it came with a blanking plate for that tbh.
Yeah would be handy, nice piece of kit though!
My X99-s seems to post a fair bit slower than my Asus Maximus VI Impact (Z87)
Maybe a quirk of the X99 system?
There was a photographic quick-start insert in my motherboard box, I thought it was pretty clear about which RAM slots to use for quad channel.
Had a play this evening on my 5820k . Sorting 24/7 and bench profiles out .
Currently @ 4.4Ghz - 1.338v
Anything more on the multi gets the chip eating voltage ... Tested up to 1.370 and can't get it stable at 4.5. Don't really want to push 1.4v threw it to get there but may have to.
Unsure on how to proceed . May hit the BClk to tomorrow and mess about with the strap .
Tweaking the ram yields unspectacular results . Using teamgroups 2400 16gb stuff @ 16 16 16 37 can tighten to CL 15 15 15 35 CR T1 @ 2400 or overclock to 2666mhz @ 1.25v , the latter seems to do nothing but worsten results. @ 1.35v I can push to CL 14 14 14 34 T1 ...
What are people doing with there Nb/cache frequencys?
You should be able to match the cache to the cpu freq, my 5930 tops and out at a cpu multi of 45 @ 1.290 volts and a cache at 45 no problem and ram performance on this platform is poor, you do not get much out of it when overclocking.
Is your cache @1.290v ?
Can't push past 3900mhz on cache even at 1.250v ... No matter what either just befor I get into windows or just after the system just shuts down , no bsod or anything ... It's fine upto 3800mhz with voltage stock
Have you tried raising input slightly? Try on a different strap. Cache on 125 strap can be a tad unpredictable. I'm at 3.85 cache for very much the same reason for 24/7. I don't do anything cache intensive anyway. With manual voltage on 100 strap 4.5 cache is easily achieved.
Don't be put off if you can't raise your cache, cache CAN scale with core frequency but it doesn't always. Without the OC socket anything over 4ghz is impossible anyway without the 'cache mod'. Note also up to 1.45v cache voltage is acceptable on adequate watercooling.
What's your CR15 score? On your head be it with that voltageWhat's your CR15 score?
Input should be good up to 2v but again, I'd keep it under 1.95v with vdroop if you can. Be wary if you haven't worked on your cache yet as the increased L3 will cause the memory to work harder
Cache at 43 1.4 is fine, can be difficult to get this stable for 24/7 above 4.4 without throwing really big volts at it.
I'm at 4.375/4.375 daily with 1.185v core and 1.25v cache, 1.92v input.
Cinebench R15 is what I meant. 4.4 core with over 1.4v is a really poor sample though, I'm sure you can get that down.
For benching though, C13 3200 is a damn nice place to be
