- 30 Nov 2010
- UK
I've made a few changes including swapping the FrSky X8R for a FrSky D4R-II so less weight, CPPM and better telemetry. Added a telemetry battery voltage sensor so my 9XR Tx alarms when battery is low, changed the 10a turnigy ESC's to 12a Emax SimonK. Also put the ESC's back inside the frame and moved the PDB under the Naze 32.
Shaved off 35g and much more locked in with the SimonK ESC's.
wonder if my better half will believe that tale?
