Yes it can go through a tank pretty fast, though I find using a higher ohm single coil helps make it last longer.
Think its biggest let down is filling it, bit awkward don't you think?
The real problem is the reduced capacity.
Can anyone here with a Moander Kayfun 4 clone, confirm if you got spares and a screwdriver inside your box? also the positive block is it a grey colour on the sides and polished ontop - Trying to work out who makes this clone lol its in a box identical to the original minus the serial sticker.
yeah the V2 can be done the same, but I only used the BD in the car so capacity was enough, but now I have the Lemo on an istick its hardly used lol
The plume is a very good atty for flavor but a leaky sod if you get your wick wrong or drip a little too much, I much prefer the CLT V2 Plus, just as good for flavour and great for vapor, but more forgiving if you overfill as the bottom under coil airflow is higher off the juice deck as are the main airflow holes.
I will be getting the 0.6 Nic base as I can't stand anything higher.
Going to get some Peach Fuzz, Slurricane, Swamp Thang, Grape Drank, Menage a Trois & some other stuff called 24 Certified which is supposed to be nice.
Roll on 10:30 when I can get out to get them!
I was planning to keep the post hole airflow closed to help avoid leaks from there at least. It does have a pretty shallow well it has to be said...
No biggie. The collection is swelling nicely, so there'll be others to play with if it does turn out to be a pain
I'm still loving the MX2 tbh. After a bit more time with it, I can definitely say that it is a step above the MX1.
From the reviews and pictures ive seen, the v1.5 plume will be no better at holding juice im afraid, Rip was not overly keen on the quality of the V1.5 either...
Im still waiting for my hobo to ship, I hear its good with an ni200 build for dna40 temp control.
Took delivery of the Tobeco Kayfun V4 last weekend, there was no bag of spares included with it either.
If its any consolation the genuine V4 doesn't come with any spares either
Cheers all
I used and abused the PV for a long time, really enjoyed it. You just have to drip little and often but it is a really nice vape.
I'll keep that in mind![]()
On another note, I've been using these batteries. They're VTC4's by all accounts unless someone can tell me different.
I've been chaining with one in a Nemesis on a .25 dual coil for the last hour or so and it's all good. Been checking it every now and then and no warmth or anything of the like.
Not yet, but I was planning to get some. Tbh though, this spring is absolutely fine and I have no issues with it. It may well get looser as it wears in, so perhaps grabbing some magnets would be an idea.
CBA to wait for FT in this case either.Yeah, I was looking at some neodymium ones on the bay. Because neodymium innit?CBA to wait for FT in this case either.
*Noob alert* What does a hybrid adapter do?
Yeah its not the fastest service from FT that's for sure!
