Not sure if anyone seen my last comment, with the F450 or F550 kit, specifically to soldering, is anyone using a flux pen before they solder? or is it not really needed.
Hi all, i'm looking for a bit of advice on my first quadcopter.....
I would like one with a camera, that is good enough quality to take still images from. As its my first quadcopter, i dont want to be spending silly money at the moment, but all i can see is the Hubsan x4's for about £50, then a massive jump up to the really expensive kit.
Is there anything in the middle? around £100-£150 that would offer an improvement over the x4?
I did consider the "baby beast" when I ordered mine, mostly because I liked the fact they were bright green!
I went for DYS 1806 in the end just because they were a bit cheaper and seemed to be well recommended
It's not strictly necessary but it does make things easier. I always use a little dab of flux on everything before I solder.
You could probably get away without it, but I think its just good soldering practice really. Ensures you have the cleanest point possible for a good solder connection.
I have been using a flux pen and water soluble flux while building my F450.
Thanks, do you think a £2 jobby pen will do the job? I have seen some which are like £15?
Also, do you think the solder I am using will do the job? it cost £1 and is 17gr 60%tin and 40%lead stuff. Apparently multicore
Both should be fine. 17gr might be a little chunky for fine work.
It will be if you're soldering wires. Pins on a board might need something thinner. It doesn't really matter too much tbh. As long as you're not using plumbers solder![]()
for what it's worth - i didn't use any flux on my Q450 and it's fine - ok, not the neatest soldering job as it was my first time in years soldering but it's all fine
I have that B&Q flux and that will be fine. Its water soluble as well, so you can just wipe if off if required.
That looks a ton of fun, can I ask what size battery's you guys use and flight times ?
A bit of flying from the weekend, I was not coping with the high winds too well and had to borrow an FPV screen as mine died!
I'm the one doing most of the crashing
Windy Winter FPV race practice - two FPV250s lots…: http://youtu.be/drsb4zryLU4
Never knew you were a member on here, I subscribed to your channel a while back.
