Is that a massive box or do you just have childs hands?
His hands don't have the right 'build' for that box.
Yup, looks well pointless!
Not![]()
Never said it wouldn't be cool, most people have something like "Ill be using it while doing *Enter sports/activity/private moments* thing.
As someone who doesn't have a dog or a Go Pro, I didn't see the point of it![]()
You could always strap it to your head and record your travels?
I don't even care if it's rubbish, I just thought it was cute![]()
But each tile is attached on it's entire surface.
A Plasma is attached via 4 plugs.
It is a bit like standing on thin ice on your toes or lying flat and spreading your weight. That's why I would be concerned.
Brilliant
Where did you get it from?
Would make a nice gift for someone I know!
pfft, try a 42" 32kg plasma
and no, that is not hanging on a wall lol
Back to physics class for you son.
So you are saying that standing on thin ice though a single small contact point is as safe as spreading your weight?
Or are you saying it is exactly the same having a tile's entire surface area making contact to the entire wall of a wall the same as 4 bolts?
Or are you saying there are zero horizontal forces place on the bolts? close as they are to the wall, not 100% of the forces are going downwards, since it is away from the wall.
