Done
Ill give cinebench a go for you. my Ram is only running about 1400 but my CPU is at 4ghz.
Im still waiting on stuff to finish the build properly so haven't finalised my settings.
Incidentally Im running it passively on a Phanteks ph-tc14pe with the case side off and rear case fan a couple of inches away. Temps haven't broken 75 even fully loaded.
I got 878
Pretty similair to my 4790k at 4.7ghz.Done
Why, because of the voltage? Triple channel shouldn't be a problem since you can buy 2+1 sticks of the same type.Loving my current setup - was thinking of getting another xeon and a lga1366 board to run as a homelab - problem is finding ram for this platform is a killer now![]()
