- 17 Aug 2003
- Woburn Sand Dunes
I thought you had posted that video because you had noticed the stuttering.
I don't think you understand the issue & I actually see it, albeit minor, in your video... does that microstutter every couple of seconds not bother you? THAT is the issue... it is more visible on the previously posted FC4 video (ignore the colour splashes).
There is a slight regular hitching in there but that's down to AC:U and using shadowplay when the gpu is working flat out - its going to hitch a little but,
it's a million miles away from what's happening in that FC3 video.
when you run out of memory performance drops off a cliff with any hardware in my experience.Using the extra memory / paging 10% of the textures will not cause the FPS to suddenly drop by 70%.
The stutter is clear in the video you posted of AC:U.
I certainly don't think it is.
