 - 5 Sep 2011
 - Surrey
Lmao. Bloody hells bells, people. Come on.
Nvidia have responded.
So, all those who are having game issues, can you tell me what games you are seeing it in please. I am happy to test and see what is what on a Titan. At least we can determine if it is indeed using more than 4GB. I am sure Kaap is happy to help out as well.
@ Kaap, Being a pain but can you test on your 290X machine as well for SoM please.
It will take a little while as I have to download it first so I will post in an hour or so.![]()
Also Nai's benchmark is bugged, people need to stop using it
Well if it runs fine on a 980 with no adverse effects using less than a Titan what does that tell you ?
That it doesn't need 4.5GB and why would it need conveniently the exact amount of VRAM 980 has? What is more likely is that it needs less than 4GB to run the benchmark (probably less than 3.5GB) and will fill up the remainder with cache/left over texture data or whatever up to a max of around 4.5GB.
Due to way Nvidia have created the memory setup on the 970 this means 3.5GB used.
Wow so the 980 (not just the 970) lose performance as well when using above 3.5GB vram "by design" according to the Nvida mod? I better stop recommending people to consider getting the 980 instead of the 970...Nvidia have responded.
I still don't quite get it... if the extra 0.5GB makes NO difference to performance, despite the way it's accessed, why have they done it exactly, and why not make it the same as the 980? Surely the only reason they would do so is to hobble the 970 so the 980 stands head and shoulders above as their flagship all singing and dancing wonder card... rather than sharing the stage with the 970, which it would surely do were it not for this 'design/fault' (delete as applicable) that they've implemented? I still half think that they realised that if they didn't do something, the 970 would be near level pegging with the 980.
If you compare how this runs on the Titans to how it runs on the 980s it becomes obvious.
 only the VRAM usage which was using more than 4GB 'because it can' which is what I was expecting.Also Nai's benchmark is bugged, people need to stop using it
You didn't post your benchmark results for the single Titan for me to make a comparisononly the VRAM usage which was using more than 4GB 'because it can' which is what I was expecting.
I'm not writing off the 970 btw just stating that I think it will use 3.5GB - 4GB and show it in Afterburner but only if it actually needs the extra which in my opinion the Mordor bench does not.
Hi Gregster, could you please test your titans in SoM in the area of Nurn please? Specifically in the first part where there's slightly more grass and a you can fight about 3-4 orcs, the second area I noticed it in is in the Orc village in the North I believe.
Both times I noticed when vram went over 3.5gb I noticed a lot of stuttering.
In Dragon Age Inquisition I noticed it in the Hinterlands specifically the woods where you fight both mages and templars.
Other games I have noticed this in are Ass Creed Unity but like someone else has said this isn't the best example hence me testing it out on the other games.
I'd be happy to be proven wrong as I feel a little gutted in getting £600 worth of cards and would much rather prefer that I'm doing something stupid that's causing these issues than have to return the cards as otherwise they are awesome and the software feels much better to use than AMD's.
System specs if they help are the following:
4790K at stock
16gb G.Skill 2400Mhz I believe
OcUK Reference 970's SLI
Superflower 1000w Platinum psu
Thanks
