- 18 May 2010
- London
Very unwise if you are worried about memory problems.
If the rumours are true and the 380X comes with HBM you may get more than you bargain for, as these cards will probably be the first to use it I suspect there are going to be teething problems and some of them could be far more serious than anything to do with the 970.
Thing is tho, Nvidia knew this was the case ages ago when they started testing silicon and throwing ideas around how to cut down the 980 to create a cheaper version. This is not something that just 'oh oops how did that happen'.
With AMD the same thing, they know NOW if there are any problems. Although coming clean as we have seen with Nvidia is a different story.
