 - 5 Sep 2011
 - Surrey
Ran the rest on my other Asus Strix 970. It drops off to 22gb/s at only 2.9gb ffs![]()
Stop using that test!
I've played it a few hours, even on lowest settings it was still unplayable.
They never fixed the stuttering, so gave up.
Wanted to see if i could replicated that video from this thread, i didn't.
3855mb with MSAA8x, 3750mb with MSAA4x. Scone reckons his 980 does the same thing @8x, probably means the 970 has 4gb usable like Nvidia said
Didn't they post something a while back that shows the 500mb of ram is margin on error slower so...nothing to fret about?
The funny part about it is thinking logically if I needed a card tomorrow based on what I have read in this thread I would have no problem grabbing the GTX 970 without a second thought.
If anyone does not believe me, remember I have a couple of GTX 960s coming tomorrow.![]()
Why are we comparing graphics cards to phones instead of other graphics cards then?
See this on Techpowerup...
“The GeForce GTX 970 is equipped with 4GB of dedicated graphics memory. However the 970 has a different configuration of SMs than the 980, and fewer crossbar resources to the memory system. To optimally manage memory traffic in this configuration, we segment graphics memory into a 3.5GB section and a 0.5GB section. The GPU has higher priority access to the 3.5GB section. When a game needs less than 3.5GB of video memory per draw command then it will only access the first partition, and 3rd party applications that measure memory usage will report 3.5GB of memory in use on GTX 970, but may report more for GTX 980 if there is more memory used by other commands. When a game requires more than 3.5GB of memory then we use both segments.
We understand there have been some questions about how the GTX 970 will perform when it accesses the 0.5GB memory segment. The best way to test that is to look at game performance. Compare a GTX 980 to a 970 on a game that uses less than 3.5GB. Then turn up the settings so the game needs more than 3.5GB and compare 980 and 970 performance again.”
Well I hope there's more Nvidia lovers who think like you. It will allow me to sell mine easier once the new AMD cards come out.
On a serious note The Nvidia response means they won't accept any fault so we are stuck with it unless and until someone comes out with some software that can test the memory and prove or disprove that the card is gimped.
If the issue is real, which appears to be the case, there's no way in hell I'm keeping this card for much longer. I'll probably switch back to AMD when they release the 380x/390x. Bummer, I wanted to stick with the 970 for a while but experiencing a hitchfest whenever the card uses more than 3.5gb vram is a massive no-no.
