Alright Alberto!![]()
Out Front mounts are much better imo, got one on my road and MTB, easier for glancing and when you've got your body down. I need to sort out some sort of mount for my TT bike as it's on the stem which certainly isn't ideal, but have my bottle mounted between my handlebars, so not really sure where else to put it. Although can now rotate screen to landscape so might relook at where it could go.
Yeah I like the out in front mount, much better for quickly and safely looking when riding.
Superstar have their metal outfront mounts back in stock: http://www.superstarcomponents.com/en/garmin-mount-black.htm
Similar to the K-Edge metal mounts but instead of £35 they are £12.99.
I'm just about to order one.
The BB cable guides do differ as I compared to the one on my MTB which had larger guides and the sealed cables would have fitted on, however the moulding was different as the holes on the frame to route the FD cable will differ. Whether or not a different one from another bike would fit I'm not sure, but since I'd cut the old cable to remove it I needed a solution so had to use the old outers. I don't ride in the rain much, just the clear plastic had started to come off the old cables as you can see in the photo which made them a little sticky.
The out front mount makes it a bit easier to read and makes the bike look neater IMO. I don't spend much time looking at it as you get a feel for the right cadence and power your legs are pushing after a while.
I don't find the out front mounts make that much difference tbh. Unless you have some kind of neck disorder, it's not really much different glancing down in front of you or glancing in front and slightly left. Craig Bellamy probably has one on account of him having no neck. Sandi Toksvig as well.
I thought it'd be quite good for TTing, so have one on the good bike and just the normal handlebar mount on the winter bike. But tbh, i never look at it during a 10 mile TT as I find it much better to judge my pace by feel (ie does it really ****ing hurt? If 'yes', continue...). Maybe if you were pacing over a longer distance or using a power meter to pace it might be good.
Obviously the main reason to have one is that it looks pro. And i suspect that's why most people do. And i'd concur that the superstar ones are good quality and at a great price.
One sided power meter for $350
That's within reach of mere mortals.
Or you can buy two for two sided power for the cost of a single sided Stages crank.
I'm going to need another mount at some point soon, as I'm fairly soon going to have three bikes on the go. I can get an outfront mount for £13 or whatever, or a laccy band stem one for like £7, so for the sake of a few quid I'd quite like to try one of the outfront ones.
The link has them for £12.99 in various colours and has free shipping (+paypal payment) too! Just ordered one!
£25 for a Garmin one from Wiggle... Are the gel cases worth getting? Not dropped or got my 810 really wet... Yet! (only a matter of time)
Any recommendations for 28mm tyres? I want to try some on my single speed bike when I get it built. No real reason, I'm just curious to see how they'd ride. The Vittoria Rubino Pro Tech cost £18 each from Wiggle and look pretty good. Any other thoughts? Vittoria do some very cheap Zaffiro ones in 28mm, and you can get Continental ones that cost nearly as much as car tyres at the other end of the scale...
Given your size and presumable weight I can't imagine you getting any benefit from 28mm. Just stick to 25mm where all the cool kids (sadly not me any more) ride.
I'm about 73Kg fwiw. Maybe I will just stick with 25mm... I can probably get some cheaper tyres at that width anyway.
I also found 28mm tyres to feel really bouncy, which makes you feel less stable on bumps and knackers your cornering a fair bit.
