Man of Honour
- 16 May 2005
- Manchester
Hmm.. Should have read it in work so I could access the full text
Can't remember my remote login details either :/
Soy, whey, rice, pea or hemp brotein...
Whey is like milk, soy is like soy milk that goes thick really quickly and pea is just vile.
But if you are a pescatarian (which I don't get but won't judge!) then just eat loads of fish: it's higher in creatine than beef or whatever, so...
Well, however you cut it that's a lot of fish per day to reach the recommendations. I just had two haddock fillets for a total of 30g of protein. And i mean, i like fish but that much, every day is a bit of a stretch on both my tastes and my wallet.
It's basically just a label filler on energy drinks there's so little in them it'll make next to no difference to anything.
Myprotein have a pretty good offer at the minute on their whey concentrate. It works out at £5.69/KG for unflavoured if you do it right and combine it with a referral code. Use "60SPECIAL" with 2x5KG unflavoured in the basket.
I guess so, the "60SPECIAL" code will work with any basket over £60 as far as I know, but the good thing about using it like this is that the Impact whey has an offer on already so is reduced.
Creatinine is what your body produces by breaking down creatine phosphate. Creatine is what you'll be seeing in supplements and as its own supplement
I'd be surprised if that was the case given creatinine is a waste product in the body. Your body wouldn't do anything with it.
Taking excess creatine can be bad however, and will cause high levels of creatinine in blood tests which can be an indicator of renal health
There are fun experiments on dosing taurine before a heavy night out due to its apparent mild protective effect (supposedly reduces hangovers)... that's pretty much all I know it does to any significant effect.
Your proposed approach is fine insomuch as there isn't any reason to not use it, nor any better proposed way...
