Do you have the correct version of the ENB files the ENB creator is using?
Sometimes they use older versions of the files.
Yep, he recommends 2.62+. Tried 2.62 and 265 latest one. Just using the d3d9.dll and enbhost files as recommended from enb dev.
Delete the ini and see if the ENB misses it. Maybe it's loading from cache or elsewhere.
Tried it. No good.
I think I give up unless anyone has any more suggestions. It only seems to allow certain parameters to have any effect by manually changing either in game on the fly, or in the enbseries ini file before you load a game. Really really weird, and totally useless to me as I need to tweak. It's a pity as this one had potential to work on.
