Finally got my 295X2 setup. Works perfectly fine with my 850W Enermax PSU.
AwesomePlease remember that any mention of competitors, hinting at competitors or offering to provide details of competitors will result in an account suspension. The full rules can be found under the 'Terms and Rules' link in the bottom right corner of your screen. Just don't mention competitors in any way, shape or form and you'll be OK.
AwesomeHow are people mounting fans either side of the rad, bearing in mine the screws that come with it are quite long.
Two screws either side?
The fans on the 295X2 rad are NZXT fans.
Yeah I have those blue tube seperators in my ebay watch list. I saw your post a couple days ago![]()
this is ground breaking stuff for us 295x2 owners so I just want to be sure as many ppl knows about it as possible...definitely look neater then zipties.
Anyone know what the screws are that come with the rad? For peace of mind I could do with 4 more.
Length and diameter.
He using the new Superflower 2000w psu
Matt, how's you're 295x2's going.
Changed anything since last time![]()
And with a 360mm AIO on top of my Phanteks Enthoo Primo case, I'd have to install the rads into the bottom.
I was really drooling over CF of dual 295X2s but in the end I didn't do it even when I already had the second card in my hands.
With my Sapphire 295X2 at stock, my card will eventually always drop the clocks in heavier games like Sleeping Dogs. Also the heat dump into out small apartment would be a bit too heavy.And with a 360mm AIO on top of my Phanteks Enthoo Primo case, I'd have to install the rads into the bottom.
By the way I asked Sapphire if changing the radiator fan would invalidate my warranty and according to them it does. Great. So either a burning hot card with warranty or a bit cooler card without warranty.
Matt, have you tried Sleeping Dogs and what temps are you getting in CF? I believe that game is the 'Furmark' of all games. Without Vsync of course.![]()
http://www.overclockers.co.uk/showproduct.php?prodid=WC-224-XS&groupid=962&catid=1523&subcat=1545
Those should be what you're looking for mate.
Happy to do a few test runs of the benchmark sequence. Name what tests you'd like me to do and how many times you want me to run them. For sure Sleeping Dogs is literally a worst case scenario though.
Thanks Matt! Well usually I just load any savegame and choose any place in game where I get 99-100 % scaling (I've seen 99 % even in 4-way SLI). Then I leave it there for up to 30 minutes so I can see max temps and if I get any throttling.
Be very careful though, don't blow up your cards or PSU with this test as it really is a worst case scenario. When SD was released, many people complained that their GPUs were overheating.![]()
What i would like to know! is would a real 4k Monitor look better?
And would the settings above feel more smoother being 144Hz compared to 4k @ 60 Hz.
if a real 4k monitor looks that same as above settings, but don't feel as smooth as the settings above, then i won't bother with a 4k monitor.
If someone (Matt Maybe) can give some feed back to this please
Cheers.
I been trying 1080p 144Hz with 200% scaling in BF4 which = 4k. Mantle,
Max settings no AA. Looks really good, that's with V.SYNC on as i get tearing otherwise.
Cheers.
