- 13 Feb 2009
- London
^^is that a GT in your SIG
Yes mate
It has a metro turbo engine inside
Boys and there toys lol
Oh i see!
what fan controller you got matt?
NZXT Sentry Mesh.
Not too fancy but does the job.
I have 1 X 295X, and a 290X Lightning. @ 1080p with 200% scaling ultra setting with 0AA, inc v.sync with a 144hz monitor, and it runs very smooth!
So not sure why you say it's no good?
Ok, so Matt, @ 60hz on you're 4k Monitor! is it smooth? and is that with v.sync on or off?
I guess i Freesync 4k Monitor @ 60hz will be ok?
Cheers![]()
NZXT Sentry Mesh.
Yes, i preferred the old look but this works better temp wise.
The top 2595x2 is exhaust, with the H110 as exhaust too. The bottom 295x2 is intake, with two 120 mm fans below it as exhaust. I'm rocking negative case pressure for now.
Good old Sleeping Dogs, nothing cooks a gpu better.
Sleeping Dogs, 4K extreme preset. Fps 65-70, gpu usage locked at 100%-98%, 30 minute test.
Information in the pictures below dakotha. I had my AMD Water Bottle on hand just incase anything caught fire.![]()
This looks good, I will defo look into this, also interested if you can run 2 fans on single header as asked previously.
In here you are 2 degrees away from throttling no ? I assume the fans were 100% ? must have sounded like a plane lift of![]()
Yes mate1275GT Clubman.
Guys, anyone tried playing Witcher 2 ? it crashes after intro and I have to do hard reboot...done clean re install of win...problem persists
Does this occur with every component inside your pc at stock?
Yes I have not touched any overclock, the arena works and the tutorial as well but when the first intro starts as witcher runs in the forest and then in the jail it goes black screen (backlight is on its just black) and no win shortcuts work/require hw reboot
Do you have any overlays running like afterburner or such? Could be something interfering with the game.
I meant it's no good for me if i get 60 fps on 144hz monitor![]()
Niiice. Love the clubman look. You doing L2B ?
Yes you can, sorry missed that question earlier.
The 2,000 RPM fans at 100% don't sound that loud at all im my opinion. The 3,000 RPM ones do though!
Got ya![]()
I used to go a lot, but not as much now due to being so busy!
Do you go at all?
Went last year. It was a lot more organised than the last time I went, the run started earlier, the run pack que went fast, they moved the minis about 8pm instead of 2amand the weather was awesome.
The only downer was some owners had there wheel nuts loosened at crystal palace in the early hours.
