AMD Radeon R9 295X2 Owners Thread
Oh i see!
what fan controller you got matt?
NZXT Sentry Mesh.
Not too fancy but does the job.
I have 1 X 295X, and a 290X Lightning. @ 1080p with 200% scaling ultra setting with 0AA, inc v.sync with a 144hz monitor, and it runs very smooth!
So not sure why you say it's no good?
Ok, so Matt, @ 60hz on you're 4k Monitor! is it smooth? and is that with v.sync on or off?
I guess i Freesync 4k Monitor @ 60hz will be ok?
Cheers :)
I meant it's no good for me if i get 60 fps on 144hz monitor :)
NZXT Sentry Mesh.
This looks good, I will defo look into this, also interested if you can run 2 fans on single header as asked previously.
Yes, i preferred the old look but this works better temp wise.
The top 2595x2 is exhaust, with the H110 as exhaust too. The bottom 295x2 is intake, with two 120 mm fans below it as exhaust. I'm rocking negative case pressure for now.
So it does make a difference when the pipes are on the bottom ! I was right !! ou yeaaaa :) Are you gonna get some of those tube spearators ? It will add nice look to your build I guess (I feel like marketing advisor for that company ! lol I should tell them to gimmie freebies :D)
Good old Sleeping Dogs, nothing cooks a gpu better. :eek:
Sleeping Dogs, 4K extreme preset. Fps 65-70, gpu usage locked at 100%-98%, 30 minute test.
Information in the pictures below dakotha. I had my AMD Water Bottle on hand just incase anything caught fire. :D :p
In here you are 2 degrees away from throttling no ? I assume the fans were 100% ? must have sounded like a plane lift of :D
Yes you can, sorry missed that question earlier.
The 2,000 RPM fans at 100% don't sound that loud at all im my opinion. The 3,000 RPM ones do though!
Guys, anyone tried playing Witcher 2 ? it crashes after intro and I have to do hard reboot...:( done clean re install of win...problem persists
Does this occur with every component inside your pc at stock?
Yes I have not touched any overclock, the arena works and the tutorial as well but when the first intro starts as witcher runs in the forest and then in the jail it goes black screen (backlight is on its just black) and no win shortcuts work/require hw reboot
Do you have any overlays running like afterburner or such? Could be something interfering with the game.
Ordered 2 of the 2,000 fans for the card! will try my 3pin y splitter to see if the card can run both fans. if it don't work i'll get same controller, as my gigabyte boards fan software suc**:D. and for some reason, speed fan don't pick up the fans lol.
I like the software on the Asus better
Got ya :)
I used to go a lot, but not as much now due to being so busy!
Do you go at all?
Went last year. It was a lot more organised than the last time I went, the run started earlier, the run pack que went fast, they moved the minis about 8pm instead of 2am :eek: and the weather was awesome.
The only downer was some owners had there wheel nuts loosened at crystal palace in the early hours.
Some sad people about, i had my new nuts removed once, couldn't believe it.
I have a garage now, as i had to, as people would just steal things..
I be back home next week, i'll show you some pics.
I rebuilt the gearbox year before last! straight cut gear, new bearing etc.
My biggest regret was adding straight cut input gears etc, as there 23 teeth and should have got 24 teeth. the 23rd is what gives you that whining noise, and it's far to loud lol i should have called it a nvidia 970 because of the whine :D opps lol joke guys ;)
you just have a 1275cc. Have you done anything to it.
Guy i know has a green 1275GT. you may of seen it at L2B run! it's really nice mini.
