Hi all.
First off
now, my system specs;
Mobo ASUS X99-S
GPU
1x R9 295x2 (MSI) @ 1055/1500
1x R9 295x2 (XFX) @ 1055/1500
CPU
i7 5930k @ 4.5GHz (and NB @ 4.5)
NZXT Kraken X60 AIO
PSU
Leadex Super Flower 2000W PSU
RAM
16Gb (4x4) Avexir Platinum 2400 DDR4 RAM @ 2400 12/12/12/24 1T
Screen
Samsung 27D850D LED 2560x1440 (Game @ AMD VSR 3200x1800)
SSD
2x Kingston HyperX 3K SSD 120GB SATA 6Gb/s (RAID-0)
Case
NZXT 810 black
I purchased my whole system from here prior to Xmas but at the time, with only one GPU (MSI 295x2 and an Antec 1000W PSU). Within a couple of weeks, the GPU failed. The AIO stopped working at the pumps though the radiator fan and card fan ran, the pumps didn’t = massive overheat and shutdown within minutes of boot. OcUK RMA’d back to MSI in about 4-5 weeks which I filled the slot with a Sapphire R9 290X 4Gb Vapor-X in the meantime.
When I received my 295x2 back, I popped it in and x-fired with my 290X but the system began to random hard reset, no blue screens or error messages, just click, off! I assumed the PSU was not up to running this set-up.
After a couple of weeks of being bored of the hard resets (even though everything was tried at STOCK!!!) which was only a couple of weeks ago now, I thought, sod it, and swapped out my 290X (now sitting on the shelf in its box) with another 295x2 (XFX) and the Super Flower 2000W PSU
(The Antec also back in its box and on the shelf)
From my following screenshots, you can see these cards run very well OC at 1055c/1500m with an under-volt of 25mV from stock and temps hovering around 62degC over the 4 cores and my CPU at around the same temp. This is running 12 “CPU’s” worth of BOINC, 10 threads dedicated to POGS and 2 to SETI (with the GPU’s running 4 tasks ea, 16 in all.) (team OcUK). No system resets or reboots, my system now runs SWEET.
So I just wanted to pop into the 295x2 thread and say hi
ty.
*Just to note, the myth about radiator and tubing orientation imo can be busted as my cards run the same temp in the orientations seen below
(bottom card just a smidgen cooler on core 1, but obvious why! And that’s the one set 90deg out from the consensus)
Question: GPU’s, no matter what voltage or power limit increase I set in AB, above 1055MHz core, during gaming/BOINC crunching, the 3D clocks will jump up and down even falling below 1000MHz quite erratically, yet when I set them to 1055, they stay there solid – no fluctuation..???? Core temps are good as you can see below, wuhyyyyy?
(driver std, no tweaks) (VRAM 3072????):
Sleeping Dogs 3200x1800 EXTREME
Sleeping Dogs 1920x1080 HIGH
