. Owned that car for nearly 6 years and i didn't think that i would ever part with it, however after 2 years with a half completed engine transplant i have called it a day.Props for the binning on day 1 antics
There may be a silver lining but it's an expensive way to change the wheels to silver
Does the E92 M3 allow more sideways action with DSC left on then or is it dependent on the drive select mode? My car will not allow traction to be lost even if there's a sniff of slip. It's annoying when you're trying to move from standstill at times or get ahead of the car beside but gives peace of mind at the same time!
With it fully on it's quite intrusive, M-Dynamic Mode gives a bit but will still catch you. This occurred in MDM, however rethinking the series of events now I've got a clearer head I'm pretty sure I panicked after minor slip, lifted off, and that oversteer.Bright red with black wheels, thats different
Bad luck about the damage to the wheel, at least its just the wheel![]()
I did that in my bmw, it bent the lower arm, the trailing arm, broke the driveshaft, the diff, even bent the diff carrier. Just sayin'.
Christ almightyUnlucky Callum. I hope there's no further underlying damage
Definitely go silver!!
Makes my little car park faux pas last night seem even more insignificant now...:
Crikey Calum, that must have been a hefty smack. Is that a new record for purchase > crash time? Wasn't there a guy on here a couple of years ago who binned an S2000 the day after he bought it or something?
Glad you're OK. And your car looks(ed) great, nice to see a non-monochrome colour on a car![]()
ThanksWith it fully on it's quite intrusive, M-Dynamic Mode gives a bit but will still catch you.
Lifting a posh M3 with that dodgy as **** jack too :/
A bit of epoxy resin and a tin of paint will see that right Vox.![]()
[TW]Fox;27634565 said:Day 1 and straight to the off button on the DSC, inspired choice![]()
is that right?
Doesn't make it safe![]()
Are you sure? There is an awful lot of weight on it, so surely that would make it fairly stable?
