I need suggestions for a boar bristle brush, the one I bought and suggested before has started to crack?! Not what I expected from a £20 brush. Gonna be returned to amazon soon.
You guys really should try plaiting your beards. Go on.... please entertain me
The wax is like a brick and I'm not sure it's really worth trying to use wax on a beard, I'd expected it to be more like normal hair wax which is soft.
You definitely don't want to use it on your beard, it's for the ends of your moustache to keep them tidy. Or twizzly.
If you do use it for your tache you just need a really small bit, scrape it out with your fingernail and warm it up with your fingers for about 30 seconds and then twizzle away.
Also you can pretty much blow-dry it (gently) with a brush after to make it go the way you want it. I do sometimes because I don't like the rock-hard moustache look but sometimes when it's long it goes all over the place so I wax it to make it behave.
Beard - check
Side of head shaved - check
Hair on top either tall or combed over - check
Skinny jeans - check
Tattoos - check
3 or more and you can call yourself an identikit hipster like nearly every other young lad these days.....
I have the potential to grow a hefty beard quite easily but once it gets to around 1-1.5cm it gets too itchy and it's trimmed back with electric hair trimmers with no attachment. I wet shave 3-4 times a year maybe.
As for people suggesting girls don't like beards, I've had a few instances in the pub when a 18-22 year old has walked past, grabbed my face and made some comment about a nice beard. a good 10-12 years younger than me and I have no idea who they are. I also worked in an office with 60-80 girls aged 18-28, I would say most like hair on a man.
The issue is, beards are now a "trend" and you get beard clubs on Instagram... it's like they are the new tribal arm band tattoos
I'm currently using the menrock mustache wax and I use the following method for how to apply it:Not had to heat it up in water at all and seems to work pretty well.
That's great but he's applying to his tash only, I was saying I wanted to control the whole beard with it (and gave up after applying some to the tash), despite it saying it's for both, it really is only for the moustache. I'm learning that to control the stray hairs in my beard I'm going to need a proper brush, the kent comb in the kit is ok but not really that great for forcing stubborn hairs into place, plus I'm sure with more balm applications it'll soften and be more controllable.
As for warming up, that depends entirely on the ambient temp of your place/where it's stored. I don't like being in a furnace and have my heating off for nearly all of the day and only on for about two hours in the evening...and then it's only at about 16C. In the mornings at the moment my place is rather chilly and the wax is rock solid and impossible to remove from the jar.
