why they don't give an other ? is with in 7 days of purchase ... mind you, if is a bad batch could be the same, so another shop maybe differentGrrrr where i ordered are claiming they can not find a fault and will have to return my device to Asus..... Credit card chargeback time LOL :![]()
Is that with spectrum killed or left running? Also did you have significantly more errors prior to this firmware?
DSL Firmware Version	1.0.2.2
DSL Driver Version	FwVer:5.5.1.127_B_A60901 HwVer:T14.F7_0.1
DSL Link Status
up
DSL Uptime
5 days 18 hours 11 minutes 5 seconds
DSL modulation
ITU G.993.2(VDSL2)
Annex mode
ANNEX_B
SNR Down
6.3 dB
SNR Up
23.2 dB
Line Attenuation Down
5.3 dB
Line Attenuation Up
8.3 dB
Path Mode
FastPath
Data Rate Down
79999 kbps
Data Rate Up
19999 kbps
MAX Rate Down
94036
MAX Rate Up
36035
POWER Down
12.0 dbm
POWER Up
-4.6 dbm
CRC Down
551
CRC Up
629
I'm currently using a TalkTalk super router, but looking for something a bit more advance.
Having had a N55U for my pre-fibre days I'm well versed in Asus, but threads like this have me worried.
Has anyone any experience of using this and say the Archer D9?
My line is of short distance to the cabinet, and it's a Huawei cabinet.
The Archer D9 is i believe an ADSL device, so if you have FTTC that will not be any use unless you just want to use it as a router and still use the Talk Talk device as the modem.
The TPLINK TD-W9980 is the device from TPLINK with a VDSL/FTTC modem built in.
Just found the Asus for £125 delivered on a competitors .it site.
Apart from a plug issue, I assume Annex A is sorted?
Yeah an EU region adapter should work fine, though its another potential issue for the device, agree though should not make a difference. Just one variable i personally would not explore.
803 still ok for almost 3 days, it seems will be okCRC's begining to rise, now at 803 down after two days twenty hours. CRC's up still zero...
i forgot about it, looking now my box, yes is included a UK & EU adaptorThe standard retail package comes with both UK and EU adapters for the plugs anyway.
